question about moving battery to the trunk
Old Dec 30, 2003 | 03:21 PM
glennxx1's Avatar
if i get like a dry cell or somethin, do i still need to put it in a box etc etc and vent it? i dont wanna vent the box, and whats the trouble i hear about starting with battery in t he trunk?
Old Dec 30, 2003 | 03:44 PM
Serene's Avatar
Gotta be in a box and sealed. Why dont you want to vent the box? its not hard...
You'll have hard starting if you dont use big enough cable. I'm using 1/0
Old Dec 30, 2003 | 03:53 PM
glennxx1's Avatar
how is venting easy? i thought you had to cut a whole for the air to get outside?, and is a "dry cell" lighter than normal batterys? ---you use zero gauge wire?
Old Dec 30, 2003 | 05:48 PM
furely's Avatar
I use an optima battery and do not have to vent it. I pass all tech inspections. I also have no trouble starting my car. I used 1 and 2 guage wire.
Old Dec 31, 2003 | 11:26 AM
glennxx1's Avatar
can i get optima battery at auto zone? what exactly would i ask for at there? just say "an optima battery" ? what volt is it
Old Dec 31, 2003 | 12:04 PM
Interesting, because the Optima battery can "gas".
And, its a wet cell, with gel added to the electrolyte.
Old Dec 31, 2003 | 01:55 PM
Serene's Avatar
eh that is not hard man...drilling a hole is easy. besides there are little plugs in the floor that you can pop out and cut a hole in them with a knife. I'm going to use 1/0 wire from the battery up front, and bring a 4 ga back to the battery switch from the alternator, to be legal
If you arent willing to drill a small hole, i would say dont move your battery
Well...3 things. You are either BSing, have a track that is easy on the rules, or you have a rear firewall installed.
8:1 In lieu of rear firewall, battery may be located in a SEALED .024 inch steel.....box. If sealed box is used, box cannot be used to secure battery, and must be vented outside of body.
Yep autozone has them, you probably want the redtop, it has 800 CCA and I think either 940 or 980 CA. 12 volt like any other car battery
Old Dec 31, 2003 | 02:02 PM
GREGG 97Z's Avatar
If you race it you also must have an external battery disconnect switch labeled on/off at the back of the car.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
cmdeshon
Dec 27, 2014 10:06 AM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
