Question about EVAP line.
Old Feb 16, 2006 | 12:07 PM
Manco's Avatar
The plastic line that goes from the EVAP cannister purge solenoid valve (mouthfull) image of it here, routes under the throttle body and goes into a wire loom containing the fuel lines. Well it broke. It was very brittle and snapped while I was under the hood jostling everything around to reseal the intake. The car seems to start and run without this line but what exactly does it do, and will it cause any damage if I run the car without it? It's a specially bent hard tube, so I assume it's a dealer item to even replace. Would it also throw a check engine soon light? Because mine is on, and it never came on before the intake job.
Old Feb 16, 2006 | 01:56 PM
Z28SORR's Avatar
Re: Question about EVAP line.
Well as the name implies, during specific engine operations the relay opens and it purges the evap canister. This is the one that collects the vapors from the gas tank. And yes it will throw a code as it's part of the emission equipment. It's shown on your emissions decal by the rad.
Old Feb 16, 2006 | 02:30 PM
Manco's Avatar
So this valve is what let's the fumes to be fed into the intake. Any adverse affects if this is not hooked up other than I might not be the most environmentally friendly vehicle on the road?
Old Feb 16, 2006 | 02:40 PM
Z28SORR's Avatar
Nothing to serious, eventually the canister will fill with vapor/gas and go bad. And of cource you'll have that code/light.
Old Feb 16, 2006 | 02:41 PM
Stoopalini's Avatar
Funny, I just broke mine as well. I strated a post to find the part number for it Here
It's about $10 from the dealer. Just replace it.
thomas.
Old Feb 16, 2006 | 03:15 PM
Manco's Avatar
thomas.
Sweet, if it's that cheap I will. Thanks for the info.
Old Feb 16, 2006 | 04:45 PM
If you leave the line off, every time the EVAP purge solenoid opens, you have a giant vacuum leak. At least plug off the vacuum connection until you replace the line.
Old Feb 17, 2006 | 07:11 AM
Sick97SS's Avatar
i broke mine and my car ran like @$$ with very high/rough idle untill i replaced it, not to mention the SES light. the dealer rushed it to me overnight for 7$.
HectorM52
Jul 30, 2017 11:46 AM
jayvar
Feb 2, 2015 10:00 PM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
