Question about dropping the motor out the bottom
Old Aug 26, 2011 | 11:29 AM
EReed's Avatar
I have a 95 Z28 Auto and I'm getting ready to drop the motor out of it. I have everything disconnected that needs to be except for the brake lines and the part of the harness that goes to the transmission. I figured that I could get the trans wiring once i have it dropped down some, but I'm not quite sure what to do with the brake lines. Especially the hard line running across to the passenger side. Should I just disconnect it at the joint where the rubber meets the hard line and at the brake box and leave it on the K-member or whatever that piece is called? Or should I go through the trouble of taking that line all the way off? I think that it has some stays going across the member and looked like it would be difficult to get off. I'm just wondering if I'm running a risk of damaging it by leaving it on there? I had planned on leaving the traction control box and the brake boxes on there as well. I'm just looking for a little guidance as this is my first time dropping a motor out of a F-body. Thanks in advance for any advice.
Old Aug 26, 2011 | 11:48 AM
Re: Question about dropping the motor out the bottom
Here's a site with a pretty decent check list.
http://www.cardomain.com/ride/348183...-camaro/page-6
Old Aug 26, 2011 | 12:03 PM
EReed's Avatar
Thank you sir!
Old Aug 26, 2011 | 01:15 PM
You disconnect the front brake lines at the ABS unit (also remove some shielding, IIRC) and fish them out as the engine drops down. You'll have to lightly bend them a little, but with reasonable care, they can be put back to right at install.
Old Aug 26, 2011 | 02:05 PM
RamAir95TA's Avatar
http://www.michiganspeed.com/enginepull/index.html
Old Aug 27, 2011 | 01:32 PM
EReed's Avatar
I'm just a couple of steps away from getting it out. The last step of course being that I completed all of the other steps....
Thanks again guys.
Alex Barnes
Jan 24, 2015 10:21 PM
sscott
Jan 17, 2015 04:30 PM
Jan 5, 2015 07:14 PM
formula218
Dec 2, 2014 04:27 PM
