Question about coil
Old Apr 8, 2004 | 08:42 AM
CMYZ28's Avatar
Question about coil
I'm chasing down a random high rpm miss etc, i was messing around checking connections and noticed my coil rocks in the mounts that it sits in.. The metal bracket is stationary, but the coil itself is able to move... I also noticed i could see some spark around it the other night, when i revved it, it would go away..
Old Apr 8, 2004 | 08:46 AM
DR.ZED's Avatar
Your coil should NOT move.
When you get a new coil, you'll need to break off the rivits that hold it to the bracket. Quite simple. Take a flat head screwdriver and smack down on the protruding side of the rivet, and it will break off. You can then push it through the bracket.
A new coil will have small bolts to use.
Old Apr 8, 2004 | 09:00 AM
CMYZ28's Avatar
thats what i was figuring.. This is an msd that's only been on the car since november...... wonder why the heck it can rock in the mounting plate??
Old Apr 8, 2004 | 09:19 AM
DR.ZED's Avatar
My experience has been that MSD coils cause problems. Go back to stock.
Old Apr 8, 2004 | 09:38 AM
CMYZ28's Avatar
same thing i noticed also, but when the motor came back from the builder last time, it was on there.. I was sort of hmm i didn't put that there, but didn't have a stocker to replace it with..
Old Apr 8, 2004 | 09:47 AM
DR.ZED's Avatar
Your GM dealer does... for $15.
Old Apr 8, 2004 | 10:48 AM
CMYZ28's Avatar
thanks i'm going to order one up this week, and see if it helps out any..
Old Apr 8, 2004 | 12:31 PM
DR.ZED's Avatar
When you take your coil off, you'll notice the bolt on the driver's most side has a bunch of wires connected to it. One of these is one of your ground straps. You can follow this wire down to the strut tower of the car. Make sure this wire is in good shape. If its not replace it with a 10 gauge wire and make sure all terminals are clean.
Always use some of that white heat transfer grease to the back of the bracket
Give us an update.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
maybe2fast
Feb 5, 2015 05:14 AM
