light brown engine coolent?
Old Mar 25, 2004 | 09:32 AM
gritter's Avatar
checked my engine coolant today and it wasnt the normal green color, it was like a light brown color like it was dirty. What could have caused this?
Old Mar 25, 2004 | 09:37 AM
PooHoopy's Avatar
96 and above GM cars came with dex cool. it is a orange color. If you car is 96 or above that could be it!
Old Mar 25, 2004 | 09:39 AM
gritter's Avatar
nope cars a 94 trans am lt1 a4
Old Mar 25, 2004 | 09:52 AM
glenn's Avatar
I have a 94 Z28 and I just drained the coolant and it looks the same. If you look close, you'll see a light green tint near the top of the jar you drained it into. Anyway, in my case, the light brown was rust. Not bad, but I should have changed the coolant more often. I'm going back with the normal green antifreeze.
Thanks,
Glenn
buelldevil's Avatar
Rust and algea. Time for a coolant change and flush of the system.
Old Apr 6, 2004 | 12:53 PM
SSnakeEater's Avatar
yeah i have a 94 Z28 and mine looks the same too.
the back of my radiator cap was all rusty.
is it something with the 94s?????
Old Apr 6, 2004 | 05:35 PM
95_Blk_Z28's Avatar
I have a very similar problem in my 1995. Everytime I drain the radiator the antifreeze looks like a light brown. I have never put that antifreeze back in. I then always fill it back up with fresh green antifreeze. Then 2 weeks later without even driving the car I drained the radiator again and the antifreeze is a light brown again. I don't know what to do. My only thoughts would be to drain the radiator and the entire block by taking out both drain plugs then completely flush everything and then fill it back up with new antifreeze. Just some thoughts.
Old Apr 6, 2004 | 09:28 PM
FireHawk409's Avatar
Mine is a 94 and the coolant is the same color. Im gonna try to flush it and see what happens.
Old Apr 6, 2004 | 10:01 PM
kingman109's Avatar
my old 94 did same thing- interesting
Old Apr 6, 2004 | 10:12 PM
pappasmerf18's Avatar
with the camaros with green coolant gm recamends a coolant change every 30,000 miles those with dew they rex the first 100,000
Old Apr 7, 2004 | 02:10 PM
uhh.... what
Old Apr 7, 2004 | 02:25 PM
IrocManiac's Avatar
Originally posted by SSnakeEater
uhh.... what
thats what I was thinking...
Old Apr 7, 2004 | 02:55 PM
no sereusly that is what they recomend i work at a shop that does all of this kinda work.
Old Apr 8, 2004 | 12:31 PM
are you sure those with dew they rex the first 100,000?
Old Apr 8, 2004 | 12:36 PM
SiDeWaYZz28's Avatar
damm you guys you are suppose to fksh your radiator every year...thats why u have all that sludge and nesty brown shiet......mines neon green no kind of sludge...thats because i flush it every year...best advice is to flush it and do it once a year.....
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
Collector Car
Jan 5, 2015 10:58 AM
CaRParts102
Dec 6, 2014 08:45 AM
dmaastr
9
Jul 1, 2002 02:22 PM
