Question for [B]Rob[/B] regarding porting the MAF
Old Dec 25, 2003 | 08:26 AM
slopokrodrigez's Avatar
What's your opinion regarding porting the MAF? ie. do you think the MAF or the PCM has to be recalibrated to show more air flow? I have my own opinion but I am interested in someone elses.
BTW I just discovered the IGNORE button. You probably knew about that function since you've been here so long.
Man it makes reading posts a lot better. Got 3 Einsteins on my list just yesterday.
Old Dec 25, 2003 | 09:52 AM
Schurters LT1's Avatar
DO NOT PORT THE MAF SENSORdo not port the maf sensor No the pcm will not see it , trust me more problems bad then good form a tuning point
Old Dec 25, 2003 | 12:48 PM
The pcm tables are calibrated to the MAF as it comes from the factory. If ported, the tables are no longer accurate. Given different mods on different cars, not all results are the same. If you port, be ready to experiment with the MAF tables to compensate. Most tuners don't like ported MAFs, as it throws a variable into the mix and makes it harder to tune.
On a side note, I ported mine long ago when it was the "thing to do" (and I was less knowledgeable). I did retain the screen and never had any drivability problems. When I got to the point of doing my own pcm tuning and after a cam install, I did make some changes to the MAF tables.
Old Dec 25, 2003 | 02:10 PM
Thanks I thought changing the MAF would change things. Just like to know I'm on the right track.
Dave
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
pete53
Dec 9, 2014 07:31 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
RedLineRev
Jan 23, 2003 03:51 PM
