Q About Valvetrain!! What Do We Have???
Old Feb 1, 2003 | 10:19 AM
COMNBYU's Avatar
i thought we have a roller set up from the factory?? (LT1s) if thats the case, i cant use reg stamped rockers, right? a friend and i were arguing over this the other day. he said he thought i could use just plain old stamped rockers and i was thinking they had to be roller.
ill be gettnig 1.6s so i need to know. and i guess if im right on this, ill also have to get guidplates and stronger pushrods, correct?
thanks for the help in advance!
jon
Old Feb 1, 2003 | 10:36 AM
drop top steve's Avatar
LT1 has stamped steel oem.
Old Feb 1, 2003 | 10:59 AM
COMNBYU's Avatar
really?? so then i could just buy some reg 1.6 stamped rockers and swap those in?? i dont have to buy those $300 set of RRs i see advertised in summit in the LT1 section? cause i can get stamped rockers for under 100 bucks.
thanks for the help!
jon
Old Feb 1, 2003 | 11:47 AM
jon
Yes you could, but the stock springs are marginal with 1.6 rockers. I would at least put lt4 springs on it.
Old Feb 1, 2003 | 06:12 PM
user guest 45's Avatar
what rocker size do we need...if we are juust doing rockers? self adjusting or not
what rockers are you looking at for under a 100.00 ?
thanks
thanks
Old Feb 1, 2003 | 06:13 PM
thanks
Old Feb 1, 2003 | 06:56 PM
COMNBYU's Avatar
thanks
most guys looking for a little extra lift go with 1.6 rockers. stock are 1.5.
as far as price, you can get Summit stamped steel rockers for between 50-80 bucks. you can get Summit rollers for $89-98 and aluminum rollers for about 150. if you want to go with the crowd, you can get the Comp Cams 1.6 rollers for 300 bucks.
jon
Old Feb 1, 2003 | 07:17 PM
which summit rockers? alumnimum and the steel one...
thanks,shawn
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
z28ponyeater
Mar 1, 2003 12:11 AM
