Q About Valvetrain!! What Do We Have???
i thought we have a roller set up from the factory?? (LT1s) if thats the case, i cant use reg stamped rockers, right? a friend and i were arguing over this the other day. he said he thought i could use just plain old stamped rockers and i was thinking they had to be roller.
ill be gettnig 1.6s so i need to know. and i guess if im right on this, ill also have to get guidplates and stronger pushrods, correct?
thanks for the help in advance!
jon
jon
really?? so then i could just buy some reg 1.6 stamped rockers and swap those in?? i dont have to buy those $300 set of RRs i see advertised in summit in the LT1 section? cause i can get stamped rockers for under 100 bucks.
thanks for the help!
jon
jon
jon
jon
Originally posted by superta
what rocker size do we need...if we are juust doing rockers? self adjusting or not
what rockers are you looking at for under a 100.00 ?
thanks
thanks
most guys looking for a little extra lift go with 1.6 rockers. stock are 1.5.
as far as price, you can get Summit stamped steel rockers for between 50-80 bucks. you can get Summit rollers for $89-98 and aluminum rollers for about 150. if you want to go with the crowd, you can get the Comp Cams 1.6 rollers for 300 bucks.
jon
z28ponyeater
Mar 1, 2003 12:11 AM
