putting together shopping list for LE package
Old Aug 7, 2007 | 12:45 PM
burnout42's Avatar
I have a '93 Corvette M6 that I am going to do a Lloyd elliot package on. I want to assemble all the parts I am going to need so I can get 'em ordered and on the car on time. My goal is 400RWHP. After speaking with Lloyd, we decided on the LE2 heads, and an LE1.5ish cam. I am going to send him my intake also and he is going to fully port it and match it to the heads. The supporting parts list so far is:
-Tpis longtube 1 3/4" headers
-Accell 36lb/hr injectors (part# acc-150836 summit racing)
-Summit Racing 58mm TB (part# sum-22703 summit racing)
**sending this part in with the intake for port matching
-SLP 160 deg. thermostat (part# sle-100224 summit racing)
Now, I know I need roller rockers, pushrods, lifters, etc.
I saw these rockers and need opinions:
-Comp Cams Pro Magnum (part# cca-1318-16 summit racing)
I don't know what lifters or pushrods to get so I need suggestions. Also, are there any other parts I am missing to install all of these things? I am trying to get an entire budget put down for these mods. Thanks for the help guys. For tuning, I am going to order a tune from pcmforless.com
Old Aug 7, 2007 | 01:29 PM
Z-RATED94's Avatar
Pick a better inj. than Accell. And you really don't need a 58mm TB for 400rwhp. Find a shop to enlarge your stocker to a 52mm. Cost about $150.
Old Aug 7, 2007 | 01:31 PM
burnout42's Avatar
what injector do you suggest, and why don't you think accels are any good?
Old Aug 7, 2007 | 01:33 PM
Z-RATED94's Avatar
SVOs are good, and do a search about the Accells. Guys have had problems with them.
Old Aug 7, 2007 | 01:35 PM
RedLT4Mike's Avatar
I have a LE package on my car.
I agree on NOT using Accell injectors.
SVO 30 or 36lb's would be best.
I've seen bad things happen with accells.
As for the throttle body, I think it's unnecessary.
I have a Holley, but I don't need it.
I'm sure a ported stocker would actually be better.
I just got it cause It looks niice
It was one of my early impulse purchases.
Old Aug 7, 2007 | 04:29 PM
2000GTP's Avatar
The Accel injectors have a pretty poor reputation, that is why alot of people on here are using SVOs or even the Racetronix injectors.
Old Aug 7, 2007 | 04:35 PM
dangalla's Avatar
i would get 7/16 non-self aligning rockers --cca-1305-16 275.95
with trick flow guideplates --tfs-30400623-8 15.95
and trick flow chromolly pushrods -- 86.95
arp 7/16 rocker studs --arp-134-7103 35.95
prices from summit
Old Aug 7, 2007 | 05:45 PM
2000GTP's Avatar
For the pushrods, you may want to hold off on them and measure first to find the exact length needed.
Old Aug 7, 2007 | 06:08 PM
FastLt1's Avatar
Don't you have to do a little modification on the SVO injectors? Are the racetronix direct bolt on?
Old Aug 7, 2007 | 09:16 PM
bdc95ta's Avatar
Racetronix injectors are a direct bolt in, & let Lloyd help you setup the valvetrain, he's the man.
-b
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
