Putting on Tierod ends....
Old May 18, 2004 | 10:24 PM
Heatmaker's Avatar
Advanced Member
Just how in the heck do you get these old GM ones off to put hte new ones on....??? I'm baffled....
Old May 18, 2004 | 11:47 PM
Before you remove them, measure and record the length from a spot on the tie rod to the center of the ball stud hole on the steering knuckle. Lock your steering wheel so the rack cannot move.
Remove or back off the nut and use a press tool made for removing the end from the knuckle or do it with the "junkyard method"- use one large hammer to "back-up" one side of the knuckle and another hammer to smack it on the opposite side on the flat portion. You can see where the flat place is a little scuffed on mine. The vibrations of the hammering should cause the tapered joint of the rod end to come free.
Don't move the steering wheel when the rod is removed. Thread your new rod on to the same length you recorded for the old one. Toe-in may be slightly impacted, so plan on having the alignment checked sometime soon.
Old May 19, 2004 | 12:43 AM
Heatmaker's Avatar
Advanced Member
Thanks...
Sounds liek this is goign to suck though.... err...allot.
Old May 19, 2004 | 04:39 AM
HBHRacing's Avatar
nah, they are really easy unless you live in the north and they are all rusted up. Just do like rob said and they will come right out.
Heathen1
Jan 2, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
WildRidez
Feb 23, 2015 07:24 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
