pushrods rubbing guideplates a problem?
Old Aug 1, 2009 | 01:28 PM
c5formula's Avatar
well i pulled my valve covers today an notice that my pushrods were rubbing against the guide plates. is this a problem or is it normal? this is on the car in my sig.
Old Aug 1, 2009 | 03:10 PM
Stl94LT1's Avatar
As long as it's not in a bind, won't hurt and is normal.
Old Aug 1, 2009 | 10:54 PM
Chevyguy358's Avatar
You should have hardened or chomolly rods if you use guideplates, if so your good.
Old Aug 2, 2009 | 03:55 AM
c5formula's Avatar
ok cool i have comp pro mag chormely pushrods so im good i guess as there is no binding
Old Aug 3, 2009 | 12:39 AM
Kevin97ss's Avatar
If the pushrods are rubbing the sides of the guide plate that is normal and there intention. If they are contacting the bottom of the "U" that is a problem and needs to be taken care of. To check this clearance put the lifter on the nose of the lobe (full lift) and check if there is clearance, .020in or more. This can become an issue with high ratio rockers and moderate cam lift.
Old Aug 3, 2009 | 12:42 AM
c5formula's Avatar
they are just rubbing on the sides of the guideplates
Old Aug 3, 2009 | 06:10 AM
SnakeOiler's Avatar
rubbing is fine, but if the rods are cutting grooves in the guideplates - that is a problem and most likely you need hardened guideplates.
Old Aug 3, 2009 | 08:04 AM
wrd1972's Avatar
What he said. /\
Old Aug 3, 2009 | 12:05 PM
c5formula's Avatar
it does look like they are rubbing some of the guideplates material away on a couple of them.
Old Aug 3, 2009 | 01:15 PM
wrd1972's Avatar
If any of the guide plate is gone, there is a problem. This happed to me years ago.
One push rod wore a 1/8" spot in one of the slots which was enough to cause the rocker to fall off the valve. This bent the PR and damaged the top of the valve stem. I was running GM bowtie plates and i determined they they were NOT hardened.
You must run hardened plates or wear can occur. If the plate is hardened, you can draw a file across it and it will not cut the surface. Better find out soon.
Old Aug 3, 2009 | 02:11 PM
RamAir95TA's Avatar
Make absolutely sure that the guideplates were installed centered under the rocker studs. This is a very common mistake that most people overlook. They just toss on the plate and tighten down the rocker studs, locking the plate into whatever position it ends up at. While it's always close, you'll notice they can still move around a bit before the studs are tight.
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Catmaigne
Dec 25, 2014 12:16 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
