PCM edit needed after header install?
Old Aug 3, 2009 | 12:42 PM
Mikes 1994 z28's Avatar
PCM performance tune needed after just a header install?
Is the stock PCM programming is adequate for long tube headers? I currently have stock programming… minus deleting rear o2’s, emissions, fans to come on earlier, increased rev limit, ext. Basically, I’m wondering if I should send it in to get a performance tune done or would I be better off waiting until I install a cam? Is there much to be gained?
Pacesetter Long Tubes, LT4 KM, Magnaflow Muffler, !cats, !AIR, !EGR, 160 t-stat
Old Aug 3, 2009 | 03:28 PM
You can pick up 10+ HP on a stock engine simply by leaning out the PE mode target A/F ratio. So a "tune" makes sense even without the header install. If you had all the other changes made, why didn't they just complete the job and lean it out? Or did you make the previous changes yourself?
Stock tune is "adequate" for the header install, in that its probably no more inadequate than it already was for the stock exhaust system.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
thenewkid
Nov 27, 2014 09:41 AM
NED4SPD
Sep 16, 2002 10:45 PM
Bando
Aug 2, 2002 02:18 PM
mjcent922
Jul 27, 2002 12:42 PM
