pushrod question...
Old Aug 17, 2004 | 08:45 PM
smokindastangs's Avatar
pushrod question...
I know this is probably a really dumb question, but if I am running a 383 blower set up, would I need a different length pushrod than the norm? I just don't want to buy some and then find out that they worn't work. Thanks for the help. Jason
Old Aug 17, 2004 | 08:53 PM
12SCNDZ's Avatar
Re: pushrod question...
Your pushrod length is affected by several things...The block being decked, the heads being surfaced, longer valves, or if you're running a small base circle cam. The easist way to check is to use an adjustable pushrod, and check the "scrub" on your valve tips. Once you have the correct contact area, order the length pushrods that you've determined from the adjustable one. The only way to know for sure if you'll need a different length is to check when the engine is assembled.
Remember, stock LT1 pushrods are only 7.2".
Frank
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
