PUSHROD length need help!!
Old Jul 30, 2014 | 01:26 PM
chuyz28's Avatar
Hello guys got a question I'm in the middle of doing a cam swap on my 96 z28 lt1im using ls7 lifters I have the comp.cam checking springs and the comp cam pushrod length checker I know piston has got to be at tdc rite and both valves closed but when I do that to check the length do I also do preload after zero lash do I go 1/4 or 1/2 turn to check the lenght then check where the mark is on valve tip from rocker right I'm using comp cam nsa 1.6 thanks guys
Old Jul 30, 2014 | 01:53 PM
Re: PUSHROD length need help!!
The amount of preload is not so important, as long as you have some. The light weight of the checking springs are not going to allow the lifter to really compress. So, it is more going to act like a solid lifter. You just want it to operate without any slack, so that the rocker stays in firm contact with the valve stem as you rotate the engine to make the witness mark.
Old Jul 30, 2014 | 03:14 PM
chuyz28's Avatar
Ok shoebox thankyou very much I apreciate it that's th only doubt I had I read ur write up help me alot
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
