Pushrod length.
Old Jan 3, 2007 | 12:51 PM
96TurboWS6's Avatar
Pushrod length.
Will 7.200" pushrods work with a stock deck block, TFS 62cc heads and .039" headgaskets?Oh and promag 1.6 NSA rockers?
Old Jan 3, 2007 | 12:56 PM
mdacton's Avatar
They will work fine....but check it anyway try one and mark the valve tip with a marker etc.
Old Jan 3, 2007 | 05:02 PM
Projectz28's Avatar
Moderator
only way to know if your geometry is correct is to check it. You can do all the math in the world and you wont get the right answer till you measure for proper pushrod length.
here is a nice thread on this topic...
http://web.camaross.com/forums/showthread.php?t=483886
Old Jan 3, 2007 | 10:24 PM
96TurboWS6's Avatar
isnt it all the same? If they work on one engine they will work on another no?
Old Jan 4, 2007 | 05:48 AM
Projectz28's Avatar
Moderator
totaly not true. stock is one thing because you havent changed to many machine tolerances. Once you change items like block deck height, heads and head gaskets, rockers and rocker ratio there is no way to tell for sure other than to measure.
heck my motor I had .010 off the block, .010 off the heads and .010 difference in gaskets and the intake wouldnt bolt up...
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
