pushrod?
Old Apr 8, 2009 | 10:20 PM
93v8clone's Avatar
pushrod?
im about to do the cam swap on my car ,im runnin the comp cc503 on a stock motor that has never been apart wit 60 k on it ,anyways im gonna run the comp pro mag 1.6 rocker in a n.s.a form wit a comp set of guidplates .question is will a hardened stock length pushrod work or will i need to change length?
Old Apr 8, 2009 | 10:28 PM
Chances are good that the stockers will be ok. When all else fails, you check the length (not that you have not seen these words before).
Old Apr 8, 2009 | 10:34 PM
deerslayinrenek's Avatar
When I did mine, the stock length worked for me......I had a set of 7.300 and I didnt need them
Old Apr 9, 2009 | 07:26 AM
user 647483's Avatar
Measure twice, purchase once.
Since you're not changing the block deck, gasket thickness, head surface or cam base circle, you'll probably end up at stock length.
Old Apr 9, 2009 | 07:30 PM
93v8clone's Avatar
i was gonna measure anyways but when i was orderin all my **** just wanted to be sure i got a set of 7.3 also but comp even said i shouldnt need em.thanks for the info though guys
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
