push rods
Old Apr 2, 2008 | 07:03 PM
ARZ28's Avatar
push rods
im looking to purchase new push rods for my 1994 z28 lt1 does anyone know what size i need are do i just put stock size back in.thanks
Old Apr 2, 2008 | 07:14 PM
2000GTP's Avatar
The stock size is 7.20" Is there a reason you want to replace them?
Old Apr 2, 2008 | 07:26 PM
ARZ28's Avatar
One Of Them Has I Slight Bend In It And I Figured They Were Out Why Not Replace Them
Old Apr 2, 2008 | 07:31 PM
ARZ28's Avatar
are comp cams high energy push rods anygood.the part number is 7808-16.i found the on ebay and they are at a place close to me.
Old Apr 2, 2008 | 07:33 PM
mdacton's Avatar
no
The cheapest good one you can get is the summit ones.
http://store.summitracing.com/partde...0&autoview=sku
I don't like those comps...the tips fall off.
If you just want a stock set I have some you can have...plenty of them
Old Apr 2, 2008 | 07:42 PM
ARZ28's Avatar
are they new or used,i dont mind buying new ones if i have to
Old Apr 2, 2008 | 07:45 PM
mdacton's Avatar
Used.....stock ones.
I replace them from doing cam swaps etc.
Old Apr 2, 2008 | 07:52 PM
Counted Out's Avatar
Aren't the 94 ones hardened already? If so, try to find some stock ones from your year.
Old Apr 2, 2008 | 09:02 PM
ARZ28's Avatar
should i use used ones or just buy new ones
Old Apr 3, 2008 | 09:38 AM
2000GTP's Avatar
As long as the used ones are fine, then there should be no issue running them.
Old Apr 5, 2008 | 04:43 PM
ssean92's Avatar
I have a set of manley I will let go, I only used them to trouble shoot my lifter issue, a few weeks ago, they are hardened 1 piece. 110 shipped, only installed a couple of them never ran car just installed and turned over while I primed. can get pic if interested
Devinfoote87
Feb 12, 2016 03:21 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Boss002
Jul 24, 2015 10:47 AM
mrwz28
Jul 8, 2015 09:11 PM
