Push rod diameter for solid setup?
Old Mar 23, 2009 | 10:19 PM
walt355's Avatar
With a solid set up can you run a standard 5/16 diameter pushrod or should i bump up to a 3/8? thanks
Old Mar 24, 2009 | 01:08 AM
cnorton's Avatar
You can run 5/16 but it's a roll of the dice if you have serious spring pressure and/or plan to twist the motor. Since they're relatively local for me, I have run Manton 3/8" with good success. I'm sure that other manufacturers have comparable parts but Manton is very responsive and easy to deal with. If you're using guide plates, don't forget to specify hardened pushrods.
c
Old Mar 24, 2009 | 01:38 PM
walt355's Avatar
Can you buy a guideplate for a LT1 with a 3/8 rod or do you havet to modify a set of 5/16 guideplates
Old Mar 24, 2009 | 02:52 PM
ulakovic22's Avatar
Comp sells a 3/8" guideplate. I'm not sure on LT's as I've always run stock style components, but check to see if you need to clearance anything with larger diameter pushrods. I know on my BBC if I wanted to run a larger PR I had to clearance on my own and had the possibility of having to run offset lifters.
Old Mar 24, 2009 | 08:16 PM
cnorton's Avatar
I used Isky adjustable guide plates with 3/8 pushrods. Guide plates for regular small block heads do NOT work. Also, it would be a good idea to check the clearance of the pushrods in the area where they go next to the intake port. I believe that we moved some metal out of the way there. Also, I removed the portion of the headgasket where the pushrod hole was located. It's been several years but I always cut that part of the gasket away. The total combination was Comp lifters (later Isky lifters) Manton pushrods, and Comp roller rockers (1.8 intake and 1.6 exhaust) and later, I put on T & D shaft rockers. If you use long rocker ratios the clearance problems become more pronounced. We were grinding away material on the inside of the valve cover lip in order to clear the pushrods as well.
Old Mar 25, 2009 | 01:11 PM
marshall93z's Avatar
Manton pushrods are FTW!
Old Mar 25, 2009 | 10:25 PM
walt355's Avatar
thanks for the info fellas
Old Mar 25, 2009 | 10:27 PM
walt355's Avatar
Im gonna be runing a crower 1:6 rocker, Comp lifters with a crane rev kit. Ive got some springs as well. thats as far as Ive got. also have a stud girtle
Old Mar 26, 2009 | 12:07 AM
cnorton's Avatar
Walt,
Let me know how you resolve the challenge of putting on centerbolt valve covers with the stud girdle in place. I had a Comp Cams girdle that always seemed to be in the way. I wrestled with that deal for several days.
c
Old Mar 26, 2009 | 11:41 AM
walt355's Avatar
Back when I first bought the thing I had it figured out, But now that you mention it I forgot about that obsticale. I better get to looking. I havent done anything at all to this car in about a year
Old Mar 26, 2009 | 01:57 PM
rskrause's Avatar
Moderator
Rev kit on solid roller with the correct springs = waste of $$$
Old Mar 26, 2009 | 05:29 PM
Ken95Z28's Avatar
Originally Posted by cnorton
Walt,
c
Here is how you do it. Took a high speed dremel and clearanced it myself.
After breaking a stud off I decided that I needed one and have not broken any yet.
I think this is Summit brand
http://store.summitracing.com/partde...2&autoview=sku
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
ModdedNerd
Feb 5, 2015 04:37 AM
alphaauto
Jan 23, 2015 07:42 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
