Timing set recomendations?
Old Mar 23, 2009 | 08:55 AM
MeenZ28's Avatar
Question Timing set recomendations?
I've read in a few different cam swap tutorials now that its a good idea to replace the timing chain and gears when doing a cam swap (logically: putting the stockers with a few thousand miles back on isn't the smartest thing to do). What I'd like to know is what set you guys would recommend (Type, Brand, part#, etc)?
I know the LT4 ED set is a good choice but ungodly expensive. I don't want to switch to a electric water pump (unless I have to) so I understand a double roller won't work. And I'm also under the impression that a timing gear set without a chain but with a middle idler gear isn't the best idea on a computer controlled car since the noise causes the thing to think there's a knock in the engine.
So What are my options? Any help would be appreciated.
Old Mar 23, 2009 | 09:16 AM
96capricemgr's Avatar
The stock set is just fine.
Old Mar 23, 2009 | 03:00 PM
Don 97 SS's Avatar
The oem set works just fine, but after seeing the GMPP LT1/4 ED one, I just had to have it.
Old Mar 24, 2009 | 06:08 PM
MeenZ28's Avatar
Really? To be honest I wasn't expecting that answer. From my experiance, stock is bad Hahaha.
Old Mar 24, 2009 | 06:35 PM
RamAir95TA's Avatar
There are several parts on LT1 motors where the stock parts are just as strong, if not more resilient than aftermarket parts (crankshaft, optispark, timing set, etc.).
Old Mar 24, 2009 | 07:39 PM
Bersaglieri's Avatar
Stock is fine for most builds
-Dustin-
Old Mar 26, 2009 | 02:13 PM
MeenZ28's Avatar
Ok, lets say that I'm uneasy about putting the stock set back on since it's clocked about 100,000 miles on it by now. What brand and/or type would you recommend as a stock replacement or slight upgrade?
Old Mar 26, 2009 | 02:22 PM
PHINES LT1's Avatar
When you were advised to use a stock set, it wasnt meant literally as use YOUR stock timing set. Use a new stock replacement. When I did my cam swap, I got my timing set from AutoZone, and it was a Cloyes anyway. Works fine under $100.
Old Mar 26, 2009 | 03:55 PM
lr383's Avatar
Ever had any troulble with stock setup.
Old Mar 26, 2009 | 05:47 PM
https://www.camaroz28.com/forums/sho...d.php?t=521308
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
