Purpose of TB bypass?
Old Mar 24, 2006 | 09:54 AM
19z28camaro02's Avatar
Exclamation Purpose of TB bypass?
What is the purpose of a Throttle body bypass? I understand how to do it, but I don't fully see the point.
Old Mar 24, 2006 | 09:57 AM
cjmatt's Avatar
Re: Purpose of TB bypass?
the only purpose it serves is to keep your throttle body from freezing up in the winter by keeping it warm, id personally like to keep it as cool as possible since mine never gets stored in temps low enough to cause it to freeze shut
3gc's Avatar
3gc
Hot coolant running through the throttle body will heat the air going into the engine. Hot air is less dense then cold air, and less air = less power. There's a dyno chart somewhere that shows about a 6rwhp gain. Not bad for a free mod.
Old Mar 24, 2006 | 09:58 AM
Z28SORR's Avatar
Allows the TB to run cooler. I know it's not much, but it's free.
Old Mar 24, 2006 | 11:14 AM
http://www.ws6.com/mod-8.htm
Old Mar 24, 2006 | 11:22 AM
97WS6SCharged's Avatar
Now we need a mod to route the freon from the AC through that TB passage.
Old Mar 24, 2006 | 12:41 PM
MyShibbyZ28's Avatar
Except the AC does not use freon. More like R134a or R-12 or something, but good idea.
Old Mar 24, 2006 | 01:42 PM
Demon's Camaro's Avatar
Or we could try what I have been pondering for a couple years now and eliminate all the vents and piping going through the firewall and use the air from the ac and hook it up to the air intake.
There would have to be some substantial gains from this as it also acts as a mild type of forced induction.
Old Mar 24, 2006 | 01:53 PM
The gains would not be worth the trouble.
Old Mar 24, 2006 | 01:55 PM
psychocabbage's Avatar
people say it "makes" more power but really the concept here isnt that its MAKING power but really allowing you access to more of the power you already make.
Old Mar 24, 2006 | 02:14 PM
Yeah yeah. Same difference. Refridgerent.
Old Mar 24, 2006 | 03:37 PM
97WS6NY's Avatar
That's what ford was gonna do with the new F-150 lightning that never ended up coming out. I was supposed to give around an extra 50 hp for about 15-20 seconds. Not exactly sure how it was set up to work, but they said they were gonna have a blade in there that when you stomped it rerouted the a/c on full blast to the intake.
Somebody ougth to take a ws6, and run their refridgerant lines under the air filter back and forth like a cooling coik, and see what kind of effect that has. I guess the a/c would have to be on though because the refridgerant lines aren't really cold unless it is moving through it.
Old Mar 24, 2006 | 04:15 PM
You would probably get a better effect if you changed the rubber connectors to aluminum, and wrapped them with brass tubing to run the refridgerent through.
Old Mar 24, 2006 | 04:50 PM
T/A Racer's Avatar
i would think that the gains would be offset by the amount of hp lost due to actually running the compressor, to cool that freon.
Old Mar 24, 2006 | 05:54 PM
06lingenfelter's Avatar
does anybody know how to do this bypass
