pullys?
Old Dec 28, 2006 | 10:15 PM
sonia93's Avatar
pullys?
I have the underdrive pully on my car but it keeps killing my car makeing it die I was told that I may need the alternator pully is this true? if so doesnt that defeat the purpose . If I need the set then who sells a good set?
Old Dec 28, 2006 | 10:17 PM
reamo04's Avatar
i believe March sells a set on summit for around 100
Old Dec 28, 2006 | 11:34 PM
Exactly how is the U/D pulley "killing your car and making it die"? Do you mean the system voltage drops so low at idle that the engine shuts down?
Old Dec 29, 2006 | 12:04 AM
sonia93's Avatar
yes when I stop at a red light it drags it down till it dies
Old Dec 29, 2006 | 01:12 AM
FireFox5.0's Avatar
I had a bad expereince with ASP's alumimum "sandwich" pulley.
http://web.camaross.com/forums/showthread.php?t=492647
Old Dec 29, 2006 | 01:17 AM
DrewHMS97SS's Avatar
maybe the belt is routed incorrectly?
Old Dec 29, 2006 | 01:19 AM
ZX636RIDER03's Avatar
who makes the pulleys that you have on there right now??
Old Dec 29, 2006 | 10:58 AM
2000GTP's Avatar
Are you sure its the pullies causing the problem and not some sort of fault in your charging system?
Old Dec 29, 2006 | 07:19 PM
sonia93's Avatar
I'm not sure of the brand but I know it was the pully cause I took it off now its fine.but I wish to put a set back on so who makes a good set?
Old Dec 29, 2006 | 07:25 PM
2000GTP's Avatar
ASP has a good reputation for making a good underdrive crank and alternator pulley, but for the very little if any gains involved, it isn't worth the money.
colts0455
Jul 7, 2015 07:19 PM
Snoman73
Nov 17, 2014 07:22 PM
vhgjk123
Aug 16, 2002 11:53 PM
vendela99
Jul 10, 2002 12:53 PM
