pulls harder in 3rd after 58mm bbk
Old Mar 24, 2005 | 04:02 PM
LT4orbust's Avatar
why would it pull harder in third gear after a 58 mm bbk throttle body, i did bore the intake out.
it also has a obd1 computer , it's a 97 firebird 350 a4 342 rear gear
Old Mar 24, 2005 | 04:20 PM
deadtrend1's Avatar
Re: pulls harder in 3rd after 58mm bbk
should have obdII if its a 97
Old Mar 24, 2005 | 04:27 PM
mojorisin's Avatar
what all does it have done?
Old Mar 24, 2005 | 06:28 PM
LT4orbust's Avatar
as soon as it warms up a little i have a cc306 , ported heads , 3200 stall going in .
now it only has a underdrive pulley , coolant bypass , 160 stat.
i heard the obd2 has a problem with higher stalls ..... i wanted to see how it would run with a obd1 anyways...which i should probably put back in ...and the above parts before i try fixing anything.
it just feels weird, first and second pull good , but third almost feels like i hit the n20 ...
Old Mar 24, 2005 | 06:39 PM
Antz97ZNJ's Avatar
I think you think its pulley harder , no pun intended....58 is huge and would only be benificial w/ serious hp
Old Mar 24, 2005 | 06:44 PM
30696bird's Avatar
I *think* it's the OBDI that has issues with 3000+ stalls. I have OBDII and a 3200 stall.
Old Mar 24, 2005 | 07:19 PM
LT4orbust's Avatar
i've heard the 58 mm gives gains in any setup , i don't know for sure. i just didn't want to have to get a bigger tb later .
about 2 seconds after third gear shifting at 6000 ... it's enough to put your head back to the headrest.... must be something wrong , thanks for any input, i'll just leave it alone untill i get the other parts installed with a better tune
almost forgot ..... the guy i bought the obd1 from said it was setup for a 3000 stall converter....i'll have to do some searching in the computer section to see who can set it up for what i have
Old Mar 24, 2005 | 07:40 PM
mojorisin's Avatar
the obd1's have a 2800 stall wall...i think
Old Mar 24, 2005 | 08:33 PM
JONEZ_Z's Avatar
Im failing to see why your car pulling hard or harder in third is a problem.
Old Mar 24, 2005 | 09:22 PM
BoltOnZ's Avatar
Seriously, I think I'd be quite happy myself
Old Mar 25, 2005 | 04:36 PM
LT4orbust's Avatar
it's not a problem, it just seems that it should pull that hard in 1 st and 2 nd too.
Peytons'z
May 6, 2021 09:25 AM
maybe2fast
Mar 26, 2015 08:34 AM
alphaauto
Jan 23, 2015 07:42 AM
Mike Meyers
Jul 25, 2002 07:35 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
