Pulling the hub, just want to double check
I searched through some of the thread relating to pulling the hub and it seems like the most available option to me at the moment is using one of the head bolts and a typicall 3 claw puller. The same one I used to remove the pulley. Will this still work for me or will I have to buy a "hub specific" puller. Mine looks very similar to the one pictured on shoeboxes site... http://shbox.com/1/pull_pulley.jpg
i used whatever tool they had at autozone, and bought a 5/8's drage 8 bolt and ground down the threads. stuck that in the crank - put the puller on it, and it pushed right off. buy the puller dont rent it, chances are someone messed up the threads.
Just got a harmonic balancer puller. It's got the crows foot design mentioned above. I guess I'll just use the bolt I already pulled out as something to push off of? Or should I use an old head bolt?
You have to grind the threads off the head bolt, so it slips in all the way to the bottom of the hole. You can't thread a head bolt in, because it has different threads. You don't want to thread a bolt in anyway.
squarehead
Jan 15, 2015 07:02 PM
teal98
15
Sep 16, 2002 01:23 PM
Rich_z28
Aug 29, 2002 10:44 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
