pulling engine from top
Old Apr 23, 2005 | 04:21 PM
gillt1's Avatar
Question pulling engine from top
Any sites on pulling engine from top? Thanks in advance.
Old Apr 23, 2005 | 04:36 PM
slverbullet's Avatar
Re: pulling engine from top
dude, i'm sure your aware of this....but it is sooo easy to drop it out the bottom. just a suggestion.
if you change your mind or are curious how hard to drop it out the bottom would be, i have some websites on how to do it.
Old Apr 23, 2005 | 05:23 PM
speedracer69's Avatar
i have done it on a firebird..
its better then doing it from the bottem because you can still roll the car around
Old Apr 23, 2005 | 05:52 PM
gillt1's Avatar
Thanks slverbullet , i'll take you up on dropping from bottom , if you could post sites ,it would be great help.
Old Apr 23, 2005 | 05:58 PM
95Z-Cross-Eyed's Avatar
I have done both, I definately prefer out the bottom. I have pulled it between me and my buddies cars several times out the bottom. That is the only way we will ever do it. Also do like we did, After we got it out the first time, put a tubular K-member in there. You will love it, especially come plug changing time.
Out the top has a tendency to bend your cal up some. Both work just fine. After we decided to try the bottom, we couldnt believe how easy it was and stuck with it.
Mike
Old Apr 24, 2005 | 11:44 AM
gillt1's Avatar
anyone have sites dropping from bottom ? thanks for any help.
Old Apr 24, 2005 | 12:47 PM
heres one: http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
ive got another somewhere. ill have to look it up later though. hope this helps.
btw- might look hard but its not really. not if you have a decent set of tools anyways. also, use a motorcycle jack to drop the k member out ($60 at walmart). that way you can raise and lower the jack as needed and provides decent stability while moving the motor. also helps with putting the motor back in. makes it really easy to line up and raise into position. let me know if you have any other questions.
Old Apr 24, 2005 | 09:03 PM
limige's Avatar
ah, people say what they want but the z is the only car i've been able to leave the hood on and pull the motor out.
first you need to pull the acessories, intake and wiring harness, yank out the tranny, fans and rad and pull it.
i'd like to try the bottom sometime then you don't have to remove so much but it is tricky.
Old Apr 24, 2005 | 09:17 PM
94zgreenmachine's Avatar
Originally Posted by slverbullet
Somehow, I don't think the method used with the jackstands was OSHA approved
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
siguy
Nov 27, 2014 10:07 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
