Pulley balance
The faster you go at the track, typically the more critical the track tech inspections are (i.e., drive-shaft loop, a cage or roll-bar at 11.49 and faster). The SFI rating is an NHRA/IHRA safety requirement (I can't remember the exact damper requirement).
At a minimum, you should probably have an SFI rated damper and flex-plate. Check with your track tech person, as these issues tent to vary (enforcement) from track to track.
WD
WD
WD
