Pulley balance
Old Dec 13, 2007 | 07:12 PM
  #16
The Engineer's Avatar
The faster you go at the track, typically the more critical the track tech inspections are (i.e., drive-shaft loop, a cage or roll-bar at 11.49 and faster). The SFI rating is an NHRA/IHRA safety requirement (I can't remember the exact damper requirement).
At a minimum, you should probably have an SFI rated damper and flex-plate. Check with your track tech person, as these issues tent to vary (enforcement) from track to track.
WD
Old Dec 13, 2007 | 11:20 PM
  #17
Per the 2008 NHRA rulebook Section 4, 1:2 Engine, an SFI 18.1 harmonic balancer is required starting at 10.99-seconds and below.
Old Dec 14, 2007 | 06:32 AM
  #18
race24x's Avatar
If I could bolt that dampener on and run a 10.99 I would buy 2 LOL I may need some other things to help the car out to run that fast
Old Dec 14, 2007 | 12:53 PM
  #19
If the damper actually worked and gave you a 10.99. Then next you should order a "Top Fuel" fire suit and you would be in the 4.50s.
WD
Old Dec 14, 2007 | 01:02 PM
  #20
race24x's Avatar
LMAO I hear yah there but a man can dream this close to Christmas cant he
AviatorDave
Dec 19, 2016 06:35 PM
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
