pulled the heads off my stock LT1 of 127K miles
Old Feb 25, 2006 | 04:15 PM
TRYTOTEST's Avatar
I decieded to go with a new short block and get some good heads and a cam to go with my blower.
I pulled the valve covers and found double coil valve springs?? are stock LT1 springs double?
This is what is looks like....
Then i got the head off and for a 127,654 miles on the motor it looks pretty good.
This is the #6 cylinder wall, How does it look?
Old Feb 25, 2006 | 04:46 PM
GreenDemon's Avatar
Re: pulled the heads off my stock LT1 of 127K miles
As far as I know, the stock springs are double coil. Mine are, anyway.
What's up with that piston, though? Did you clean it or something? Looks way too clean to be off a running engine...
Old Feb 25, 2006 | 04:49 PM
Javier97Z28's Avatar
Moderator
Pics aren't showing up.
You're saying you have dual-spring valve springs? If so, no, LT1's do not come with dual spring valve springs.
Old Feb 25, 2006 | 04:51 PM
GreenDemon's Avatar
Not a true double coil, but have that flat wire coil in the center- for dampening oscillations or something, I believe.
Old Feb 25, 2006 | 05:26 PM
TRYTOTEST's Avatar
Yea, weird i can see a thin metal spring inside the outer spring.
On my old 96 LT1 they didnt have that inner spring thing.
No i didnt clean any of the pistons, the thing looks new, i dont get it, im starting to wonder how many miles are on this LT1.
Old Feb 25, 2006 | 05:29 PM
TRYTOTEST's Avatar
here is the link to the pics
http://community.webshots.com/user/NicksCamaro1021
Old Feb 25, 2006 | 07:06 PM
GreenDemon's Avatar
Looks strange to me, those pistons look remarkably clean for a high mileage engine. The chambers are nice & dirty but the pistons appear to have been recently installed?
Old Feb 25, 2006 | 07:28 PM
97WS6NY's Avatar
that is how mine looked when I took the heads off a couple of weeks ago with 120,000 on it. IDK, maybe they just tend to stay clean
Old Feb 25, 2006 | 07:37 PM
GreenDemon's Avatar
I suppose so. I haven't had the heads off mine yet, so LT1s are new to me. The other engines I've seen looked a lot dirtier than that though. Maintenance and average throttle input might have something to do with it too. Kind of like a perk for people that floor it a lot, I guess.
Old Feb 25, 2006 | 09:20 PM
94Camaro_Z_28's Avatar
Thats how mine looked at 138,000 when I tore it apart. Those springs also look the same as the ones on my 94.
Old Feb 25, 2006 | 10:20 PM
HardcoreRM125's Avatar
As for your cylinder walls:
They look fabulous for that kind of mileage. What type of oil do you run? Those lines you can see on it, thats from honing a cylinder. Usually after a few thousand miles they look like yours. And once you got your miles on it, they look smooth. No visable lines ( Inless you had a catastrophic failure )
The pistons look very clean, but from what I have seen on this board, alot of people have extremely clean engines once they tear them down. There was someone a few weeks ago with 100K+ and still had hone marks on the cylinder walls.
Old Feb 25, 2006 | 10:35 PM
Evil Eric's Avatar
mine still had crosshatch marks on the cylinder walls at 130k, Ive never seen an engine that clean after that many miles. I literally scooped sludge out of my heads and lifter valley the first time I tore an lt1 down. Those arent stock springs.
Old Feb 25, 2006 | 11:19 PM
1racerdude's Avatar
Pistons and spring's and block look normal. Can't tell if the spring has a flat dampener or an inner spring. If it's got a round wire inner spring it ain't factory..
Shhhhh I would rebuild that cherry in the back yard. Have a shop deglaze the cyls,check the crank,vat it,install new cam brgs, new rings and brgs,oil pump and timing chain set,new ported heads,cam,RR's and go have some fun.
Old Feb 26, 2006 | 07:08 AM
89385formula's Avatar
My stock engine was very clean just like that at 96K miles, and the heads were definately cleaner then those. Every LT1 that I have had the heads, with the exception of mine had 120K+ miles and could still see the crosshatch in the bores. My cam bearings were still beat though, and the crank/bearings weren't real great either.
Old Feb 26, 2006 | 08:35 AM
Scotts94z28's Avatar
I wonder what mine will lool like, approaching 230,000.
