ptv problem maybe
Old Dec 14, 2007 | 02:49 PM
thebufenator's Avatar
ptv problem maybe
alright, I have my new engine on the stand, and am almost done adjusting the rockers.
Here's the problem:
as I crank over the engine, it got alot harder now that the valvesa are moving correctly. I figured it was just compressing, but now it almost acts as if something is touching. It gets real hard to crank over, then the force I am pressing against disappears. Is that normal?
383 5.7 rods -5cc dish
le3 head/cam/intake cam installed staight up
CC ProMag 1.6, TF guidplates, ls7 lifter, cc chromoly pushrods 7.15
Old Dec 14, 2007 | 03:40 PM
96m6lt1's Avatar
not for sure!
rods could be hitting the cam,this has happened to others before and the cure was to get another cam that is on a reduced base circle.is your pan off so you can watch the rotation?
Old Dec 14, 2007 | 04:28 PM
without the rockers installed it rotates fine without the rods tapping the cam.
I already had to clearance them.
Old Dec 14, 2007 | 05:57 PM
mdacton's Avatar
Did you check PTV?
if not check it....
Other than that could just be the valve springs......I have kind of a heavy spring and you can't hardly turn the engine over at all. With the plugs in it you need a breaker bar
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
