Protecting wires from headers?
Old Feb 6, 2004 | 09:59 PM
NONO5.0's Avatar
Can anyone recommend anything to do to the plug wires to help them against the heat of headers? I thought about rapping them up in some header tape, but don't know how hard it would be to run the wires afterwards. Just tryin to get some suggestions.
Thanks!
Old Feb 6, 2004 | 11:21 PM
AsianSensation's Avatar
It might not be a bad ideal to go OTVC routing if you have not already done so.
Old Feb 6, 2004 | 11:46 PM
ibanez6rg's Avatar
OTVC!
Old Feb 7, 2004 | 09:01 AM
Like My Taillights?'s Avatar
take your time and direct the wires at least an inch from the headers and you'll be fine. Zip ties are you friend. no need to go otvc, but it does look pretty cool!!
Old Feb 7, 2004 | 10:29 AM
NONO5.0's Avatar
I had heard about otvc setups but I've never seen one. Does anyone have a pic of them installed? I have the Corvette fuel rail covers and valve covers...can I still run otvc setup?
Thanks guys!
Old Feb 7, 2004 | 10:32 AM
SlickBlack Z's Avatar
After I did my headers...one of my spark plug wires was VERY close to a primary tube. At the time I didnt see any other way to route it, so I used a section of fire sleeving to cover the area where it was close...the fire sleeving was actually touching the primary tube (I know now this was not smart). Well, after a few weeks...the header burned a hole in the fire sleeve, and then into my plug wire...and it started arching! My car was missing terribly and running like crap. Once I realized what it was..I got under there and made sure I routed the wire differently. I wrapped up the 'injured area' with electrical tape and still have the fire sleeve over it...but it's got about 3/4 inch clearance now...and no problems since. The moral is just be sure to route your wires VERY carefully. Take your time, and as mentioned above...zip ties come in very handy.
Old Feb 7, 2004 | 10:34 AM
ibanez6rg's Avatar
Here's what mine look like:
http://images.cardomain.com/member_i...07_12_full.jpg
http://images.cardomain.com/member_i...07_43_full.jpg
Old Feb 7, 2004 | 10:44 AM
Thanks guys!
I also have Corvette FRCs and Corvette valve covers. Yes, it can be done but the Corvette valve covers are too pretty to go OTVC. So I went side mount.
http://www.97ta.com/trans_am_photos/transam39.jpg
http://www.97ta.com/lt4/lt485.jpg
http://www.97ta.com/lt4/lt510.jpg
Old Feb 7, 2004 | 10:49 AM
SiDeWaYZz28's Avatar
HEY YOU GUYS WHERE DO YOU GET THOSE OVER THE VALVE COVER WIRE KITS IMMA NEED THEM AFTER MY HEADERS BURN MY WIRES UP....THANKS
Old Feb 7, 2004 | 10:51 AM
ibanez6rg's Avatar
You can get them from www.thunderracing.com
Old Feb 7, 2004 | 10:52 AM
thank you
Old Feb 7, 2004 | 01:10 PM
NONO5.0's Avatar
Nice job! Where did you get the side mount kit from? Did you have to use the Taylor custom cut wires or just the regular Taylors? Are those headers TPIS brand? (that's the kind I have )
Thanks to everyone for all the good info!
Old Feb 7, 2004 | 01:40 PM
Got it from Thunder Racing. Where else? They have 2 kits you can get. OTVC and side mount. The wires are universal wires. My headers are FLPs.
Old Feb 7, 2004 | 02:35 PM
My95Z's Avatar
I didn't do OTVC at first.. learned very quick.. I bought some taylor spiro pro form thunderracing.com and did the OTVC and they are sweet.. especially in the blue color!!
Old Feb 7, 2004 | 02:55 PM
Kataklysm's Avatar
Will the OTCV work with MSD 8.5 MM wires or do I need a set that is longer? It seems like the MSD wires barely reach in some cases.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Omega9
Aug 2, 2002 12:33 AM
CobraEatr
Jul 23, 2002 06:32 PM
