Proper Valves?
Old Dec 10, 2003 | 10:10 PM
Heatmaker's Avatar
Advanced Member
Arrow Proper Valve Springs? B-Easie!
What are the proper Valve springs needed for a 1.6rr with future plans of an aggressive Street Cam...?
Who makes em?
How can one tell if they have Aluminum heads or not...it's a 95 LT-1...
I think thier aluminum...but how can I be sure?
Thanks you guys are awsome
Old Dec 10, 2003 | 10:53 PM
PoorMan's Avatar
Springs depend on the lift. Need to make a cam selection first.
You don't want to get a spring stiffer than you need because it's unneeded wear on the valetrain. If you have a 95 Z28, you have Al. heads
Jeff D.
Old Dec 10, 2003 | 10:59 PM
Heatmaker's Avatar
Advanced Member
224 / 230, .502 / .510 112 LSA
along that lines
Old Dec 11, 2003 | 12:02 AM
NightTrain66's Avatar
The Combination Motorsport # 612 spring, retainer and lock kit will work fine and require no machining. Less than $100 and requires NO MACHINING. The XE 230/236 (or smaller) will be fine with these springs.
NightTrain66
Old Dec 11, 2003 | 12:05 AM
Heatmaker's Avatar
Advanced Member
I'm guessing gettign ride of this Crapatelli and going with some kick *** Rockers is deff a more certain HP mode.
MadMav
Jun 15, 2015 09:51 PM
dylan1303
May 22, 2015 12:24 PM
JurisAg02
Jul 27, 2002 11:49 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
