proper oil pressure
Old Nov 29, 2008 | 11:23 PM
z28camaro1090's Avatar
proper oil pressure
where should theses lt1s oil pressure be at idle after the motor is warm
Old Nov 29, 2008 | 11:35 PM
69z-28's Avatar
20 psi or so i thought...
Old Nov 30, 2008 | 03:54 AM
..DAMN..'s Avatar
Mine at idle is around 17-20psi and under load it's anywhere between 25-42psi.
Old Nov 30, 2008 | 04:57 AM
henryz28's Avatar
Mine is over 70psi when first started. Then drops to about 50psi when the motor is warm, but as soon as I go wot the pressure is over 70psi. Running 5-30. I think mine is high though.
Old Nov 30, 2008 | 09:49 AM
user 647483's Avatar
Are you running HV oil pump?
Old Nov 30, 2008 | 12:40 PM
Fuels94TA's Avatar
Mine idle at 20 psi once warm up
Old Nov 30, 2008 | 01:02 PM
hotheadbuddy's Avatar
you want at least 20psi on a sbc or lt1 when engine is completly warmed up. ls1 will run about 40psi due to disign.
Old Nov 30, 2008 | 02:38 PM
thanks guys mine runs between 18-22 psi just wanted to make sure its normal
Old Nov 30, 2008 | 04:17 PM
That's plenty. Minimum GM spec is 6 psi at idle for an LT1. Any lower than that and the check gauges light will come on.
Old Dec 1, 2008 | 11:06 PM
henryz28's Avatar
I have not changed the pump myself, but I bought the car used and the oil pan is beat up on the bottom. I never removed the pan so I don't know if the pump is stock. Every thing was stock on the car though and it only had 50,000 on the clock. The owner said nothing was done to it, but I think the oil pump was upgraded. I even blew out the oil sending unit once and was dumping oil out the back of my car and onto my bumper, I thought the main seal was out but was glad to find that my oil sending unit was the problem.The oil gauge is close to pegged when first started, so it can't be a stock pump can it?
Old Dec 2, 2008 | 02:54 PM
Javier97Z28's Avatar
Moderator
Sounds like an HV pump. Your oil pressure sounds similar to mine.
Old Dec 2, 2008 | 08:29 PM
marshall93z's Avatar
Oil pressure is overrated!
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
