proper install height
Old May 16, 2008 | 10:53 PM
  #16
RallyBoy1's Avatar
With a 400# open valve spring pressure, what would be likely to happen?
Old May 16, 2008 | 11:04 PM
  #17
Stl94LT1's Avatar
Originally Posted by RallyBoy1
Are you saying that I will need another .050" to make the installed height 1.95"?
I had a set of springs installed on my heads at 1.825". Valves were +.050, stock locators, and regular retainers. A couple of the valves only needed .015 shims to acheive that installed heigth. Which would leave a maximum 1.840", and with a +.050 retainer that would be a 1.890" maximum installed height. So, my heads need an additional .060 to get 1.95".
Old May 16, 2008 | 11:11 PM
  #18
RallyBoy1's Avatar
Basically, the springs that I have chosen are not ideal for my application. If I were to use them I will probably kill my lifters or break something else I guess. I don't see how Lingenfelter used these springs with so much open pressure in their lt1 engine builds.
Old May 17, 2008 | 07:52 AM
  #19
RallyBoy1's Avatar
i guess there is no way to make these springs work? I hope I did not waste my money. Could I buy better lifters??
Old May 17, 2008 | 10:28 AM
  #20
Stl94LT1's Avatar
If Lingenfelter was using these springs on their 219/LT1's, they will work. Maybe give them a call and see what is needed for the install.
Old May 17, 2008 | 05:06 PM
  #21
SS RRR's Avatar
Yes they will work but it's important to achieve the proper install height.
Old May 17, 2008 | 10:56 PM
  #22
RallyBoy1's Avatar
Providing that I can achieve proper install height of 1.9, what can I do about the excessive open spring pressure? Would I have to run solid lifters? What lifters did you run?
Old May 18, 2008 | 04:18 AM
  #23
SS RRR's Avatar
I had those springs on my LT4 heads assembled by LPE w/ the 211 cam. I can't tell you what the install height was. Never checked it at that point and I've moved on since then. I was using stock lifters at the time w/ no issues.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
robcarnut
Mar 20, 2015 03:40 PM
Collector Car
Jan 5, 2015 10:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
