Programming differences? LT1 vs WS6
Old Jan 31, 2004 | 02:06 PM
JeffsWorld's Avatar
Were there any differences in the programming out-of-the-box from GM between the LT1 and WS6 equipped cars? Would an LT1 benefit from having WS6 programming flashed? I can only assume there would be a difference in air ratios with the ram air and all, but would there be anything else?
Old Jan 31, 2004 | 02:25 PM
Kain's Avatar
I seriously doubt that there is a difference between the programming. IMO, it'd be more worth your time getting something from PCMforLess.
Old Jan 31, 2004 | 02:46 PM
Antz97ZNJ's Avatar
There is no differance, its the same car
Old Jan 31, 2004 | 05:49 PM
xxsaint69x's Avatar
yes there is... THE MAF tables are different for the Ws6
Old Jan 31, 2004 | 05:59 PM
gb95zconv's Avatar
Thats correct...Ive seen this disscused on the lt1edit list several times.
Old Jan 31, 2004 | 06:03 PM
97FormulaWS-6's Avatar
Correct... to account for the different intake track losses experienced from the 2 very different intakes.
Old Jan 31, 2004 | 07:07 PM
Antz97ZNJ's Avatar
I stand corrected
Old Jan 31, 2004 | 07:19 PM
Originally posted by Antz97ZNJ
I stand corrected
Though, I am still trying to figure out about a pre-98 WS6 that is not an LT1. <shrug> The question threw me.
Old Jan 31, 2004 | 07:23 PM
Chris 96 WS6's Avatar
Being that I own a WS6 and have been using LT1 edit for 3 yrs, let me shed some light:
There is only 1 difference between the standard LT1 tune and the WS6. As someone stated above, the MAF table is different. It is actually curved LOWER in the WS6, I am not exactly sure why this was done, I'd have to work through the logic of it vis a vis how the PCM sees the MAF output. However, if you put the stock LT1 MAF curve in a WS6 car would probably run rich. Timing and everything else is exactly the same.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
bond2
Aug 8, 2002 09:04 PM
