Proform Cam Checker Tool - Dumb Question
Old Nov 9, 2005 | 08:14 PM
Z28barnett's Avatar
Thanks for reading this post.
I ordered a proform cam checker tool. It slides into the lifter bore and holds a dial indicator.
I thought this would be a good solution to checking the cam and my installation.
I dawned on me that I might not be able to use this tool with the heads on.
Has anyone used this tool?
Will it work with the heads on?
Z28
Old Nov 10, 2005 | 05:25 AM
HungryT/A's Avatar
Re: Proform Cam Checker Tool - Dumb Question
Why would you use this cam checker? Just curious..
Old Nov 10, 2005 | 01:41 PM
NeverEverSatisfied's Avatar
What in the world does the heads being on the car have to do with using that tool? To be checking a cam you would need the tappets to be pulled anyways.
Old Nov 10, 2005 | 08:22 PM
Z28barnett's Avatar
I would like to check that the cam is degreed properly, that is why I would use it to check lift at .050 with a degree wheel to get the lobe centerline and check my work.
The heads overhang the block towards the intake. The cam checker has a large dial at the top. If the dial hits the heads, then you won't be able to slip it into the lifter bore. That is what I am concerned about.
I get the impression that some people have not seen this tool. Here is the link to it in Jegs.
http://www.jegs.com/webapp/wcs/store...0783&langId=-1
Z28
chuyz28
Feb 19, 2015 12:50 AM
maybe2fast
Feb 5, 2015 05:14 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
