procharge kit
me and my friends were talking and they have tuners that are super charged - turbo charged etc. and they said that i should procharge my 95 z28. so what im asking is where to get i good kit for a good price and wont crap out on me and what else i need to do. i currently havent done any mods to the car so any other recommendation would help alot. it a automatic with 90xxx miles on it if that means anything. thanks for the help guys
Re: procharge kit
Stock f-bodies do not take well to boost. Not to mention the astronomical price of supercharger kits nowadays - $6k for a new kit. You're also starting in the hole since you have zero modifications. Unless you have a TON of money to burn you're heading down the wrong path. A properly supercharged engine needs to be built to handle the boost - minimum $3000 for the bottom end, a GOOD exhaust, the list goes on.
For the price, you could have a more reliable heads/cam/bolt-on LT1 with more power than a supercharger alone.
Re: procharge kit
Not to mention the unfortunate temptation of new supercharger owners who immediately put on a smaller pulley and tempt fate...
Re: procharge kit
OP, my advice to you is to save up some money and read this forum for an hour every night for the next few months.
Re: procharge kit
I should point out that my reliability statement is based on the decision to supercharge a stock motor with a stock bottom end. If the motor is built to handle the boost properly then yes, the reliability would be similar.
Re: procharge kit
not to steal the op's thunder but what is the ideal cr i would need to run 8 lbs of boost right now i have all forged internals lt4 intake lt4 heads ported and polished, cam block is bored .20 and my cr right now is 11.5:1. i have been told that is way to high to boost it but i want to get some other opinions.
Re: procharge kit
But if it were me, I'd go between 9 and 9.5:1. I will certainly agree that 11.5:1 is way too high for ANY amount of boost.
Re: procharge kit
i appreciate the info man so it looks like i will just go with the funny gas to get what i want on the track. pocket book is to tight to buy a new set of pistons rings and all the **** for the blower. thanks again for the help
Re: procharge kit
Do not go cheap on the "funny gas"..... or you will need new pistons and rings and maybe a whole new engine. I've been running nitrous almost since my car was new, starting with an NOS 125HP dry kit on the stock engine in 1995, and now running a 300-shot on a totally forged 381 that was specifically built to handle that kind of power. I've burned a few plugs, and suffered from a a minor "pop" that bent up my throttle blades, but limiting the damage is the result of installing the correct components, and tuning, tuning, tuning.
