problems removing oil filter
Old Sep 24, 2009 | 01:52 PM
Daryl1148's Avatar
I was wondering if anyone could point me in the right direction when it comes to removing my oil filter. It turns out a 15 minute job is now turning into a all day problem. I went to change my oil today and noticed my oil filter was excessively tight and noticed a small dent in it. When i finally got it loose, the entire part that it connects to came off the engline block. It has two lines coming off it which i believe run back to my radiator. The filter keeps spinning and will not come off. Do i have to unscrew the one bolt and remove the entire assembly it is connected to and then try and remove the filter? I guess the good news is i can screw it back on but i know it is not a good idea to use the same filter again for another 3,000 miles. Thanks
Here is a picture of what i'm up against:
http://i155.photobucket.com/albums/s...8/IMG_0834.jpg
Old Sep 24, 2009 | 02:33 PM
RUDEDOG's Avatar
Do a search on oil cooler delete. You don't need it.
Old Sep 24, 2009 | 05:34 PM
Daryl1148's Avatar
Nevermind, i got it. I had to take the oil cooler lines off. It was a lot easier to remove it when your not laying on your back working upside down. Lesson learned: Don't over tighten your oil filter.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
