Problems with my LT1
Old Mar 14, 2004 | 07:42 PM
c0rey's Avatar
Angry Problems with my LT1
Hey what should I check on the z I got it home today. I don't think there is anyway for people to put **** in my gas since I had the locking cap. It has fuel and has spark as well. Sparking from both the coil and the opti. Getting Fuel. Fuel Pump works. Anyone have anything I can check gonna see about the pcm if there are ways to check it. Anyone have any ideas?
When I try to start it just pops outta the exhaust. Has new fuel filter as well.
Let me know what to check Im up for anything now.
Old Mar 14, 2004 | 07:52 PM
dnlFF's Avatar
Ignition Control Module <------
Old Mar 14, 2004 | 07:55 PM
HBHRacing's Avatar
it's not the ICM if it has spark. what did you do about the Gas Corey?
Old Mar 14, 2004 | 07:56 PM
c0rey's Avatar
I haven't done anything with the gas yet. Like I said since I had a locking cap I dont think they put anything to it.
Old Mar 14, 2004 | 07:58 PM
HBHRacing's Avatar
you better make 100% sure before you go any further.
ohther then that.. start with a fuel pressure test since your getting spark
Old Mar 16, 2004 | 02:11 AM
c0rey's Avatar
Draining the tank any other Ideas?
Old Mar 16, 2004 | 03:33 AM
96LT1TX's Avatar
check under valvecovers..
i had a no start problem and it was a broken valvespring
Old Mar 16, 2004 | 07:14 AM
Dan Oldham's Avatar
I would suggest tapping on the PCM with a screwdriver handle to see if the car stumbles, but since it's not running, I guess it wouldn't do you any good.
It could be the Ignition Control Module. Also check fuses. You could have a burned out fuse.
If all fails, that's when I would pop off the valvecover gaskets.
Old May 7, 2004 | 02:43 PM
sleeper94z28's Avatar
Angry
im having the same problem with my z.. i just replaced the cap and rotor since i was getting a weak spark.. when i tried to start it, it would just pop out the exhaust like the timing is way off but the opti only goes on one way... im so frustrated plz help
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
