problems getting off the second piece on the balancer (hub)
Old May 10, 2004 | 06:35 PM
meangrn94ta's Avatar
i pulled the balancer off and now i am left with the hub and i have bent 2 3 jaw pullers tring to pull it off. when i did my cam swap i thought i used a 3 jaw pull but cant remember. do i need to go and buy the hub puller?
Old May 10, 2004 | 06:42 PM
turbo_Z's Avatar
the secret is you need to push against the bolt that hold the hub on. just unscrew it half way and try that... may need to keep unscrewing the bolt a little and pushing against it till the hub falls off.
Old May 10, 2004 | 06:44 PM
well i screwed it half way out and tried that and it is still bending the screw pin on the 3 jaw puller.
Old May 10, 2004 | 06:46 PM
turbo_Z's Avatar
Oh well i am not sure then... .get yourself a hub puller instead of a 2 or 3 jaw puller.
Old May 10, 2004 | 06:48 PM
ok thanks i just didnt want to go and buy it and not need it
Old May 10, 2004 | 06:52 PM
turbo_Z's Avatar
FWIW I rented mine from autozone... not sure if they still rent tools out to the public though.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
