Problem! Vibration in the steering wheel
Old Mar 28, 2004 | 04:45 PM
jayman117's Avatar
I recently got a new opti, wires and plugs. I know the guy had to take off the water pump, powing steering, and alternator to get to the dam stuff. When I got my car back, I noticed a vibration in the steering wheel, if i'm in neural and I bring the rpms up to about 1500, the steering wheel bounces up and down and shakes. Also at idle, is it normal for the lt1 to shake a little? It seems like it does that more too. Its not a constant shake, on and off. And down low in the rpm band my car still feels like its chugging...i'm just getting frusturated b/c i just spent $1400 and i'd expect everything to be good..this type of stuff keeps me up at night!
Old Mar 28, 2004 | 05:39 PM
dnz28's Avatar
He took off alot that should not have had to come off, by power steering do you mean the pump or the rack?
Old Mar 28, 2004 | 05:56 PM
jayman117's Avatar
i believe the pump...i think he took off the harmonic balancer too. My car just doesn't run as smooth as it used too, which shouldn't be after all this new stuff
Old Mar 28, 2004 | 06:36 PM
dnz28's Avatar
Its possible the opti was forced on, which would screw the timeing up, also might have some wires backward. simple stuff just double check the guys work.
Old Mar 28, 2004 | 07:07 PM
jayman117's Avatar
any idea why the steering wheel shakes?
Old Mar 29, 2004 | 11:16 PM
jayman117's Avatar
any ideas?
Old Mar 29, 2004 | 11:44 PM
VegasZ's Avatar
Make sure there are no intake elbow leaks. This will make your engine run rough and shake the wheel.
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
SLIMJIM
Jan 7, 2003 11:06 AM
formula79
Aug 6, 2002 11:18 AM
