Problem with my LT1
Old Nov 1, 2007 | 01:09 PM
mad95lt1's Avatar
Problem with my LT1
Having a little problem with my lt1 and kinda stuck on what it could be. Ran it the other day to work(20min drive) ran perfect. When i left work tried to start it, would crank but wouldn't turn over so i looked at it today back at my house and noticed no spark and no fuel due to injector failure. The injectors look fine, coils great, everything seems to be in working order at first glance, but before i go checking every little bit someone mention to me earlier that it could be the computer failing? Any ideas or tips of what to look for would be helpful
thanks
Old Nov 1, 2007 | 03:02 PM
irishz28's Avatar
how do you know its injector failure? could possibly be a pcm gnd.
Old Nov 1, 2007 | 03:16 PM
94YellowTAGT's Avatar
My brothers is doing the same thing. I have done some posting on here and some say it could be a leaky injector causeing the fuel system to lose pressure. It makes since. When your car does start do you notice any blue smoke from the tail pipes?
Old Nov 1, 2007 | 04:07 PM
If there is no signal from the opti, you don't get spark or fuel injector operation.
Old Nov 1, 2007 | 04:34 PM
capp's Avatar
clean it, if it doesnt work then its something else. start with the cheapest and simplest and move up.
Old Nov 1, 2007 | 05:30 PM
dangalla's Avatar
this sounds like what your looking for, the first thing you may want to check is the harness going down to the opti. it starts up next to the intake on the passenger side
Old Nov 1, 2007 | 06:41 PM
mad95lt1's Avatar
hmm, ill check the opti, I guess i ruled it out because its almost brand new, less then 1K miles on it, but knowing how sensitive they are i guess it could be.
thanks
Old Nov 2, 2007 | 07:38 PM
OBE1 95Z28's Avatar
Before yanking the opti, very the opti cable is making good contact.
Old Nov 3, 2007 | 09:11 AM
A simple scan would show up codes if the Opti isn't supplying the high and low res pulse signals. Why guess - scan it.
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
