Problem with LT1 need help!!
Old Nov 28, 2007 | 09:23 AM
lt1552's Avatar
I recently changed my water pump on my 95 formula and while putting back on the wires on the opti-spark crossed some up. I took it to a friends shop and had him fix it. Afterwards the car ran as smooth as it did before and I had no misses. On the way home i got in it a little and when I came to the next stoplight my motor sounded crazy. It sounds like their is a huge air leak but my headers seem to be sealed properly. The valvetrain sounds a little noisy too but no knocking of any sort and the car runs and idles perfectly except for a loss of power while driing around and that sound like the motor is sucking in or losing a ton of air. I have no idea what is going on. All help is greatly appreciated.
Thanks,
Heath
Old Nov 28, 2007 | 11:21 AM
BUBBA's Avatar
Make sure your intake is connected to the TB correctly.
Old Nov 28, 2007 | 11:51 AM
lt1552's Avatar
had a couple people look at it and they think it may be the oil pump, they said it sounded like oil wasnt getting to the top of the motor... does this sound right??
Old Nov 28, 2007 | 02:18 PM
mrmint69's Avatar
Is your oil pressure reading normal?
Old Nov 28, 2007 | 04:36 PM
joeSS97's Avatar
Did you check for a loose spark plug?
Old Nov 28, 2007 | 06:47 PM
lt1552's Avatar
the oil pressure guage reads nothing and it says check guages... Not sure if its just the guage itself tho??
Old Nov 28, 2007 | 06:53 PM
LT1CST's Avatar
Well if your oil guage says it reads nothing. What do you mean by that? as in when you start the car, the oil pressure gauge does not move? Does it move a little bit? Is underneath the red area. If your not getting any oil pressure reading, I would adivse against driving it right now. You dont want to blow that motor.
Chris
Old Nov 28, 2007 | 09:38 PM
mrmint69's Avatar
If thats true the sound would be bad.
Old Nov 28, 2007 | 10:54 PM
jay_rich's Avatar
The car should shut off as soon as it senses no oil pressure...I had a hose pop off when i first go my car (on a trip) and it shut off on me.
Jay
Old Nov 29, 2007 | 05:13 PM
lt1552's Avatar
when i start it it does not even move. It just stays at the farthest left position and says check gauges...
Old Nov 29, 2007 | 09:42 PM
LT1CST's Avatar
If the gauge meter is over to the far LEFT. Then the gauge is Pegged. Did anyone remove the intake manifold or something? I didnt and my guage is to the left as well (pegged) I took my intake off and accidently hit a wire leading to the sending unit on accident. So now I have Auto meter gauges in car to read the oil.
Chris
Old Nov 30, 2007 | 08:41 PM
mpsalmon's Avatar
check to make sure that the oil sending unit did not get damaged. If the valves are rattling bad then the oil pump is not functioning. If this is the case you need to check it and make sure. If it is not functioning then you are going to have to pull a bearing cap and check to make sure that none of your bearings got burned. It doesnt take long for a bearing to get damaged. The oil sending unit is on the back side of the motor and nearly imposible to get to.
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
