Problem with idle after LTCC install
Ever since I have changed to the LTCC to get rid of the opti I have had some little problem with my idle. It doesnt do anything on startup but when I put the gas on and after letting off it will drop down below 500 rpm then stay there for a second or two then go right back to 1k. It has only once just died because of the rpm dropping so low then it started right back up and was fine. Also to better explain the scenario it is like when your at a drive thru and you move up a car length then put the clutch back in it does it. Anybody please help out.
F(ast)-body
Feb 26, 2003 09:05 AM
slothgrant
Aug 22, 2002 03:01 PM
