Problem after hot startup has me stumped.
Background/info on engine:
Forged 383CI engine
worked AFR 195's
224I/234E @ .050 w/ 1.6rr
LTCC coil on cylinder setup
Coated Pacesetter LT's w/ dual 3" into single 4" exhaust
Auto/2600 stall
ect. ect.
Well i just got my 383 setup running a few months ago and it runs great and i couldnt be any happier. but lately ive been having a problem and its been bugging me.
The problem im having is that when i start the car when its hot like after i stop to get gas or something it runs strange for a short time.
it seems that when i hot start the car it idles fine in park or in gear but when you give it enough gas to accelerate a little it feels like it has a leak past the mass air sensor, the revs just dont want to climb it just has a loss of power like its running on 4 cylinders. but if you give it some more gas it will all of a sudden feel like someone just switched on the other 4 cylinders and from that point out it will run fine. and the problem wont present itself untill i turn it off and wait a minute then re-hot-start it.
Im just a little stumped about this problem because it only happens for a moment or so and then goes away and the car will run fine.
Any suggestions or ideas on how to fix this problem would be greatly appreciated.
THANKS in advance!!!
Forged 383CI engine
worked AFR 195's
Auto/2600 stall
ect. ect.
Re: Problem after hot startup has me stumped.
I assume you don't have a fuel pressure gage in the car since you didn't mention it. If not get, a hosed gage and tape it to the windshield so you can see what it's doing when the problem occurs.
You really should have a fuel pressure gage in the car with that setup.
