problem after header install?
Old Aug 15, 2007 | 10:41 AM
sn8ke eatr's Avatar
well i finished hooking up theheaders, o2 sensors in.i took it around the block and it was running fine, then all of a sudden it began to bog and lurch and feel like it wants to stall, although it dosent. it idles but not right. what do you think my problem. plug wires? if anybodies got an idea that would be awsome, thanks
Old Aug 15, 2007 | 11:03 AM
Bowtie_Z28's Avatar
If they are new headers let the car idle for about 15 minutes or so, this should clear up as it is pretty common while the car finishes burning off the extra oils and such that are on the headers. Also you may end up needing to replace the O2 sensors.
Old Aug 15, 2007 | 01:07 PM
2000GTP's Avatar
Start off simple, check all the plug wires, make sure they are all seated properly and you didn't burn any of them on the long tubes.
Old Aug 15, 2007 | 01:40 PM
9formula4's Avatar
be willing to bet its the O2 sensors. They get messed up after header installs. I was always told it is better to have a new set ready to go in after the initial heatup of the headers.
Old Aug 15, 2007 | 06:51 PM
mrmint69's Avatar
O2's : but it usually happens after a little bit of driving and not so obivious at first. I would bet you burnt a plug wire like me and it ran like i unplugged one and was running on 6 or 7 cylinders. It almost burnt through and went from smooth to crap in minutes. Mine was the drivers side 3rd back. It is right on the pipe and i ended up using an old plug that was longer and running it over the top.
Old Aug 18, 2007 | 10:30 AM
slowride94z's Avatar
What did you do to fix this? I also just installed Lts and have a rough problem. new plugs and wires + coil, I solder my wires on o2.
Old Aug 18, 2007 | 10:50 AM
Razor_Blade's Avatar
[QUOTE=slowride94z;4812360]What did you do to fix this? I also just installed Lts and have a rough problem. new plugs and wires + coil, I solder my wires on o2.[/QUOTE
I fixed mine with some O2 extensions and a new pair of AC Delco O2 Sensors.
Noenav
Mar 1, 2019 07:38 AM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
