problem after head $ cam swap
ok i took my car for a ride yesterday and i was running it pretty hard. i whas a wot when all the sudden it lost alot of power, so i let off the gas and it died so i coasted to a stop and started it back up. my oil pressure was really low so i limped it home and turned it off, let it cool, and started it up. my oil pressure was fine and it ran smooth as ever. so i took it for a ride. the oil pressure was fine untill i starded geting on it then it did the same thing again
Originally posted by z28_4life
i just got done with my cam swap and mines at about 40-45 (little over the half way mark).
Re: problem after head $ cam swap
Im having the exact same problem.. except I have had my cam and heads in for a long time... all I recently did was change the lifters out...
Would that affect the oil pressure???
Originally Posted by ibanez6rg
Rockers adjusted correctly?
if your having the same problem i would suggest parking it until you fix it. i blew my motor shortly after my last post
Holy crap, im scared now. My car is doing the ecact same thing. just got heads ported and installed the LT4 hot cam. Oil pressure is way low, but car iwont hardly idel either. I was thinking a PCM job was going to fix all of this. What do you think?
F(ast)-body
Feb 26, 2003 09:05 AM
