problem after head $ cam swap
Old Apr 30, 2004 | 10:26 PM
1FASASZ's Avatar
ok i took my car for a ride yesterday and i was running it pretty hard. i whas a wot when all the sudden it lost alot of power, so i let off the gas and it died so i coasted to a stop and started it back up. my oil pressure was really low so i limped it home and turned it off, let it cool, and started it up. my oil pressure was fine and it ran smooth as ever. so i took it for a ride. the oil pressure was fine untill i starded geting on it then it did the same thing again
Old Apr 30, 2004 | 10:44 PM
ibanez6rg's Avatar
Rockers adjusted correctly?
Old Apr 30, 2004 | 11:00 PM
1FASASZ's Avatar
i think so. could that affect oil pressure?
Old Apr 30, 2004 | 11:06 PM
ibanez6rg's Avatar
Well how low is your oil pressure, first?
Old Apr 30, 2004 | 11:18 PM
1FASASZ's Avatar
between the red and the 1/4 mark. if i rev it a little it goes up to the 1/4 mark and if i let it idle it will go down into the red and the check guages light comes on
Old Apr 30, 2004 | 11:23 PM
z28_4life's Avatar
i just got done with my cam swap and mines at about 40-45 (little over the half way mark).
Old Apr 30, 2004 | 11:29 PM
1FASASZ's Avatar
thats were mine is when i first start it. and thats were it was befor the head & cam swap
Old Apr 30, 2004 | 11:35 PM
97WS6SCharged's Avatar
When you changed your springs, did you ever change the oil after a hundred miles or so? New valve train components are known to shed a little metal.
Old Apr 30, 2004 | 11:36 PM
ibanez6rg's Avatar
A lot of LT1s see around 20 (1/4). Cold startup is around 40-45.
Old Jul 20, 2004 | 10:00 PM
CoUnTryMuZiCZ28's Avatar
Re: problem after head $ cam swap
Im having the exact same problem.. except I have had my cam and heads in for a long time... all I recently did was change the lifters out...
Would that affect the oil pressure???
Old Jul 21, 2004 | 11:42 PM
1FASASZ's Avatar
if your having the same problem i would suggest parking it until you fix it. i blew my motor shortly after my last post
Old Jul 26, 2004 | 02:24 PM
Hardee46360's Avatar
Holy crap, im scared now. My car is doing the ecact same thing. just got heads ported and installed the LT4 hot cam. Oil pressure is way low, but car iwont hardly idel either. I was thinking a PCM job was going to fix all of this. What do you think?
Old Jul 26, 2004 | 04:24 PM
DarkHorse's Avatar
I had this problem a while back after I swapped cam/valvetrain.
I removed the factory oil cooler and the junk Fram oil filter and now everything is fine.
mikey4play
Mar 15, 2015 11:45 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
F(ast)-body
Feb 26, 2003 09:05 AM
