Is this a problem?
Old Dec 18, 2008 | 09:09 AM
2manyToyz's Avatar
Is this a problem?
I have more of the white condensation smoke/steam you get when it's cold coming out the left side of the muffler more so then the right. This is NOT dual exhaust, so just wondering if the muffler is/has taken a dump . I believe it is OE - stamped GM. Still sounds ok, no leaks that I have found.
Old Dec 18, 2008 | 09:34 AM
zcardriver22's Avatar
I wouldn't be concerned about it.
Old Dec 18, 2008 | 10:58 AM
bombebomb's Avatar
If its only "smoke/steam" when its cold and you first start, then nothing to worried about. If it starts pouring steam out, then worry.
Old Dec 18, 2008 | 02:08 PM
twcblackhand6970's Avatar
Wait, so if it's lets say 30 degrees out (*F) and you see smoke/steam after your car has warmed up you should be concerned?
Old Dec 18, 2008 | 02:13 PM
IPrice's Avatar
A good complete combustion will cause water from the exhaust...whether it's in a liquid or gas form.
So, unless it's blue or white smoke (and constant)...go buy yourself a Dr. Pepper and think about that.
-Ivan
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
