probably a stupid question, but
Old Apr 16, 2004 | 08:08 AM
sharp396's Avatar
Post probably a stupid question, but
whenever you replace your opti, do you need to set the #1 cylinder to TDC?
Old Apr 16, 2004 | 08:10 AM
buelldevil's Avatar
no
Old Apr 16, 2004 | 08:36 AM
Ricardo's Avatar
No you do not . The opti will only go in one way, with the cam drive pin inserted in the drive hole. If your camshaft timing was set right with the timing marks on the sprockets aligned everything will be OK.
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
