Prob. w/ Intake Manifold
Old May 18, 2004 | 11:02 PM
leadfoot94's Avatar
Exclamation Prob. w/ Intake Manifold
I'm in the middle of my cam swap right now. We just RTV'd the block set the gaskets down and torqued the intake. Everything went very smoothly, until I noticed that we didn't bolt on the oil pan/tray thing that bolts to the bottom of the manifold!! The one that went bolted up correctly would sit just above the lifter retainer.
Does anyone have any idea if I could just leave it out, and what it's real purpose is? Shoebox? I really don't want to have to pull the intale again. Please help...
Old May 18, 2004 | 11:18 PM
It keeps hot oil from splashing on the bottom of the intake manifold. It helps prevent oil mist from getting sucked up in the PCV system.
Old May 18, 2004 | 11:24 PM
leadfoot94's Avatar
So I imagine it would be best to take it back off and install it with the pan. Is that what you would recommend?
Old May 18, 2004 | 11:27 PM
It would be best to have it on there. You will probably get more heat soak in the manifold with it off.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
