Priming the oil pump
Old May 6, 2005 | 02:47 PM
tylerdj's Avatar
Okay we need some help on my brother's engine. Does anyone have a write up or can help me out on how to prime the oil pump on an LT1? Thanks ahead for the help!
Old May 6, 2005 | 02:56 PM
btchincamaro's Avatar
Re: Priming the oil pump
Only way I know of is to pull fuel pump fuse, pull spark plugs and crank away.
Old May 6, 2005 | 03:01 PM
SStrokerAce's Avatar
yep or pull the injector wiring to the ecu out and the coil and crank away
Old May 6, 2005 | 04:17 PM
joshp007's Avatar
How long do you crank on it? Sorry to sound dumb just never done it before
Old May 6, 2005 | 10:25 PM
Blownbird355's Avatar
Just watch the oil pressure gauge in the car. Should start building after 3-5 sec.I just pull the to 7.5 amp injector fuses.
Old May 7, 2005 | 01:59 AM
BlackLT1_TX's Avatar
it will get up to 40+psi. just pull the fuses.
Old May 7, 2005 | 06:33 AM
93black-ta's Avatar
whats the point in turning the engine over to pre lube it? i thought the point was to make the oil pump lube the engine before its turned over. ive always heard "take the intake off and manually rotate the oil pump", i believe thats the best way.
Old May 7, 2005 | 02:20 PM
well, being that everything should be covered in assembly lube/cam lube, a few revolutions to build oil pressure is fine. it is alot different then starting the motor.
Old May 8, 2005 | 07:18 PM
pearlpurple's Avatar
To me this is a very accurate statement.
When I rebuilt my 350 for my truck when I was assembling it I ensure every surface got lubed, and I primed the oil pump but if I hadn't primed it I still think it would have been fine.
With the LT1 you still prime it from the top but with the intake off right??
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
